Do I need an oil cooler? >
Old 05-15-2003 | 07:17 PM
SledgeHammer's Avatar
Default Do I need an oil cooler?
I just bought a rebuilt 468 putting out about 500 HP. It came with a 11 quart oil pan but no cooler. With the large oil pan, is it necessary to have the oil cooler?
SledgeHammer is offline
Old 05-15-2003 | 08:42 PM
rayseaeddie
only if you want it to live. your marine engine is under constant load and generates a severe amount of heat. oil temp control of 210 to 240 is pretty standard now. if you checked yours after a hard run I guarrentee temp of close to 300.(bring the french fries). save yourself some headaches and buy a stock 500hp cooler setup with thermostat . oil also cools pistons and helps prevent detonation.
t500hps
07-17-2012 09:23 AM
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
