Marine Assault Quad Rotor 540 Project
The project is to the stage of installing it in the boat. For those interested the entire engine build through dyno testing is posted right here All of the individual projects ......CLICK HERE.......
It is 11 very detailed write ups long with dozens of pics. Scroll down a little bit for the beginning. Take your time.
Probably the only place you will find how to info on installing a Quad rotor setup.
Quad Whipple how to install
For example stuff : Piston Clearance and Fitting Rings
Finding exact TDC and degree the cam.
It will be installed in a 23' tunnel boat made in Oklahoma. We expect 130ish MPH from it.
Will document the installation in the boat also. It has been very successful so far. If we survive the speed runs, it will top it off.
Enjoy
Quad Whipple how to install For example stuff : Piston Clearance and Fitting Rings
Enjoy
