Dyno Results
Old 05-19-2003 | 09:37 AM
Default Dyno Results
I'VE RESENTLY DYNO MY ENGINES, WE WERE LOOKING TO GET 1000HP, WE GOT 978HP AT 6200RPM 5# OF BOOST TIMING AT 32 GAS 110. HOW WOULD THESE COMPARE TO MERCURY, STERRLINGS OR KEITHICKET ENGINES 1000HP? DOES ANYONE HAVE DYNO RESULTS
THANKS RON
FAX# 207-797-8950
rbourgoin is offline
Old 05-19-2003 | 09:55 AM
Turbojack's Avatar
We need engine specs. On only 5 lbs of boost. I do not see why you could not top the 1000 mark with a little more boost.
Turbojack is offline
Old 05-19-2003 | 10:01 AM
632 CUBIC INCH, 8-71 BLOWER TWIN 1000CFM CARBS, NO INTERCOOLER, WE WANT RUN THE ENGINES AT A LOW RPM AND 5 TO 6# OF BOOST FOR LONGEVITY
Old 05-19-2003 | 10:06 AM
HOW MUCH BOOST DO THEY RUN?
Old 05-19-2003 | 10:07 AM
Turbojack's Avatar
Motor should last forever at that boost. Any reason you did not install an intercooler? Intercooler may give you the extra 22HP to make 1000 & it will help to keep motor from detonating.
Old 05-19-2003 | 10:17 AM
Merc 800SC's run 8 lbs of boost with a 420/671 blower.
Griff is offline
Old 05-19-2003 | 10:51 AM
jdnca1's Avatar
My 10.5:1 632" made 900HP (@6700) tunnel ram (2X775 race demons) on 93 Octane. At 6200 power was around 870. My motor likes 32 degrees as well.
Cam is 280/288 @.050 with .730 lift on 115 C/L.
With 5# of boost you should easily be getting 1000HP, what heads and cam are you running.
jdnca1 is offline
Old 05-19-2003 | 11:29 AM
Biggus's Avatar
Wow!!!
Ron, what`s your estimate on top speed?
Weren`t you running 118 with the 850`s?
Looking forward to see it on the lake soon
Kurt
Biggus is offline
bobby daniels
Need a bigger Blower its trying to suck the guts out at 5lbs the heat would be lower also
Old 05-19-2003 | 12:48 PM
Kurt, we only reached 104mph with 820hp were hoping to reach 118-120mph
the heads are 350 MAGNUM AFR , COMP CAM 715 LIFT DURATION AT .050 FOR INTAKE IS 264 EXHAUST 264 GROSS LIFT 215, THE REASON FOR NO INTERCOOLER WAS HEIGHT AND THE 8-71 BLOWER WE HAD NEW FROM OUR LAST ENGINES, TRING TO KEEP THE COST DOWN, WE WILL PUT 10-71 BLOWER SOMETIME THIS YEAR OR NEXT.
YES, WE NEED A BIGGER BLOWER
