MERC 2.4 Carb & 6 years >
Old 05-21-2003 | 02:01 AM
Bob Ricter
Stored it for 6 years in as gravel floor warehouse in Minnesota.
Now we want to get it running & sell it & a near new HydroStream VEGAS 20' V for $11500. (a small buck for the 83 MPH ride YA!)
We will:
Flush fuel system
change plugs, gear lube
& Impeller...
What else B4 that 7,000 - 83 MPH run?
We want a 24-35' FORMULA or 101 MPH pocket rocket. VASSERETTE, ALLISON or ...
Thank you.
Old 05-21-2003 | 11:50 AM
mcollinstn's Avatar
I'd premix 20:1 with Merc Hi perf oil and run 2 gallons thru it like that (in addition to the oil injector if you are running one - 16:1 if not). Before you spin the crank, spray wd40 into all the cylinders and then one by one turn the flywheel by hand to BDC and spray each one again.
There's a chance that you have some rust pitting on the rod needle bearings so run it at high idle (2000 rpm) for the first few minutes.
Good luck. I've got an 8-year 2.4 in a barn myself.
mcollinstn is online now
tssteph
Wanted
2
07-31-2008 08:14 AM
Two B.A.D.
19
01-12-2008 10:48 AM
PicChic
12-12-2007 01:32 PM
Dock Holiday
05-07-2003 11:23 PM
