List of true deep v hulls. >
Old 05-21-2003 | 09:19 AM
KN
Default List of true deep v hulls.
I would like to make a list of all the hulls that are true deep v's. No pads, steps or anything else. From past to present, including years and models that have changed (ie. Cigarette Top Gun) As well as manufacturers that are no longer in business.
Thanks, Kirk
KN is offline
Old 05-21-2003 | 09:34 AM
Default Sonic
Uses a 25 degree deep V.
wannabe is offline
Tantrum's Avatar
Active Thunder
37's can still be ordered without a step
32 No step
28 No Step
25 No Step
All 24* hulls with no pads.
Tantrum is offline
Old 05-21-2003 | 09:40 AM
JUSTONCE's Avatar
all excaliburs
JUSTONCE is offline
Old 05-21-2003 | 10:04 AM
madbouyz's Avatar
C R Hunt must be spinning in his grave .......
Surely all the early Bertrams should be at the top of the list !
madbouyz is offline
Old 05-21-2003 | 10:11 AM
Dave M's Avatar
Veteran: Navy
30 Superboat pre 2000
24 Superboat pre 1998
Dave M is offline
Old 05-21-2003 | 10:32 AM
X-Rated30's Avatar
What is your definition of a Deep-V hull??? 24Degrees? 22 degrees? 26 degrees???
X-Rated30 is offline
Old 05-21-2003 | 11:42 AM
KN
I thought the 24' Pantera has a small pad, as well as the Baja's
KN is offline
Old 05-21-2003 | 03:15 PM
Caincando1's Avatar
Baja Outlaws
correct me if I'm wrong but didn't they just add a small pad to some of the outlaws.
What about a notched transom?
Caincando1 is offline
Old 05-22-2003 | 07:33 AM
How about a 260 Powerquest? 23 degree no step or pad
Gary C is offline
