Spark Plug gap , AC Delco Rapid Fire 1 >
Old 05-26-2003 | 08:41 AM
Default Spark Plug gap , AC Delco Rapid Fire 1
Does anyone know the correct gap for these spark plugs?
They have the extended tip for better burn.
Motor is a 540 with Thunderbolt 4 ign.
sheikman is offline
Old 05-26-2003 | 09:56 AM
obnoxus's Avatar
Charter Member #1171
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-26-2003 | 10:22 AM
CESSNA
RAPID FIRE AND SPLIT FIRES ARE A RIP OFF <<JUNK ,I had a guy from sterling tell me thursday there like STP for your oil ,But Like
P.T. Barnum(of circus fame) said there is a sucker born every min
But hey run them I'm not slaming anyone for their beliefs I do stupid stuff too !
Old 05-27-2003 | 07:37 AM
sheikman1
Default AC Delco
I can appreciate your concern Cessna but if you compare NGK, AC plugs, Champion Plugs you will see that the Rapid Fire Junk reaches furthur into the combustion chamber hence better chance of not fouling at low speeds.
Old 05-27-2003 | 05:20 PM
bobby daniels
Most plugs are avalibile in extended tip -
Just for chits and giggles today I compare a rapid fire and a extended tip plug and they were either the same or the autolites were longer ,just my 1 cent worth
and they make tips for oil burners that schroud the tip (hide it ) from the oil and ect in the cylinder not put it out in it ,go with a MSD box and regular plugs you'll think you had your motor rebuilt
Old 05-27-2003 | 06:46 PM
26sonic's Avatar
bobby daniels with the msd ignition on a 502efi what would you gap the plugs at ? using either ac delco or ngk standard length plug?
26sonic is offline
Old 05-27-2003 | 09:21 PM
bobby daniels
Stay with 40 on the plugs ,it (the msd) really helps idle ect and ect. use one of their e type coils or the blaster 2
Old 05-28-2003 | 06:01 AM
sheikman1
Default MSD Box
Bobby,
Good point on the MSD box.
Can I hook the MSD into the Thund IV ignition ? and how do I wire this up.
2nd question... I was told that Autolite plugs were a good choice for my motor but was never able to figure out which one.
Any help here
RJ
Old 05-28-2003 | 07:00 AM
Pwrbt33's Avatar
Talking still running I sea !!!
sheikman1,
I see the motor is running good. Great to hear. So how does the boat like the 540 ?
Pwrbt33
Pwrbt33 is offline
Old 05-28-2003 | 10:39 AM
bobby daniels
Default Re: MSD Box
Originally posted by sheikman1
Bobby,
Any help here
RJ
P.M. your head type and comp.ratio,and cam and I'll be happy to help with plugs ,,,autolite work fine I can get the number with info
shop for a MSD 6al box jegs or summit ,but shop ,hope you do it it will help
