gimble bearing
Ditto on autozone for the puller. Went to the hardware store with the gimbal bearing and put together the pipe fittings needed to make a driver. Make sure the driver only contacts the outer race and you should be good to go. Don't forget to line up the grease holes either.
Good luck... pain in the ass job!
BT
BT
