Add oil in gas? or no.....
I recently bought a 30' Donzi ZF w/ twin Mercury 250 EFIs. The engines are oil injected but I was told to add some oil to the gas anyway to keep the injectors lubricated. Is this true should I add a quart when i fill up?
Dealer:
I wouldn't. If your engines are stock, too much oil could actually build up as carbon deposits in the combustion chambers, sometimes called "coking".
THis is because oil burns hotter than the fuel, so if you run it rich on oil, it could "coke" up, and that's not good.
Mercury Marine spent gozillions designing those motors/injectors. While no company or design is perfect, if they don't tell you to add extra oil, don't.
My $.02
Good luck with your Donzi!
My $.02
288sunny
Do It Yourself, Boating on a Budget
3
07-15-2008 08:11 AM
