Where do I mount depthfinder? >
Old 06-03-2003 | 01:52 PM
elimin
Default Where do I mount depthfinder?
I have a 2002 eliminator 26' daytona cat.I presently have the depthfinder mounted underneath the drivers seat and about a foot toward the transom.It works about 25% of the time. I have bought a new one because the old one is epoxied to the hull.I need to know the best place to mount it so as it willl work most of the time.Any ideas or suggestions on where to put this on the hull would be greatly appreciated.
Old 06-03-2003 | 02:32 PM
HyperBaja's Avatar
In front of the steps, but far enough back so it is in the water when planed off.
HyperBaja is offline
Old 06-03-2003 | 03:03 PM
Official OSO boat whore
It won't work in a cat hull unless you set it really deep. Be satisfied with the 25%.
Cord is offline
Old 06-03-2003 | 06:50 PM
H2Xmark's Avatar
you might have to run it mounted on the transom, they look ugly on the back but they do work
H2Xmark is offline
Old 06-03-2003 | 10:07 PM
SledgeHammer's Avatar
Can you move it further back to keep it in the water more often? Hook your transduce up and then seal it in a baggie of water and move around till you find the best spot. If your hull is cored it won't work. Doesn't the manufacturer have a suggestion?
SledgeHammer is offline
Airpacker
1
04-22-2008 09:50 AM
kennyo
2
02-20-2008 02:07 PM
East Coast B
04-19-2005 07:02 AM
Stormrider
Active Thunder
2
10-21-2004 08:40 PM
