External GPS antenna, where did you mount?
Just bought a new fixed mount GPS for the Sonic and am trying to decide where to mount the antenna. I have a spot on the dash or right next to the GPS mounted above the dash. I thought of mounting on the outside on the driver's side just behind the running light, but I am concerned about it getting broken when walking around the deck.
Where have you mounted yours? I know it needs to have a clear view of the sky.
Into any flat surface that sees the sky (for instance, surface in front of dash) drill (or saw) a hole large enough to take the foot of the GPS antenna. Sink foot of GPS antenna into hole, glue with 5200. Presto, antenna & cables out of the way.
please consider this
I mounted my antenna on its base at the port gunwhale top surface. probably 1 foot from the stern, tucked next to the rail that surrounds my sun deck. right near a side engine compartment vent.
I USED VELCRO to attach the base (2" diameter) to the hull. and then ran the antennae wire through the vent. only see about 4 or 5" of the white wire tucking into the vent.
then i installed the unit on it's base on my helm with velcro too.
DRILLED ZERO HOLES anywhere. and if the antenna ever get's bumped, it just topples over, and i stick it back in place. makes it easy if the future owner wants the gps or not some day down the road too.
the stern location also lets me use the bimini and full camper top. you want GPS and a top up both in a storm !!!
good luck
if i remember, i'll take two pics in the morning before heading to work.
good luck
here's the pics
well sorry, guess i cannot post attachments as i don't have a paid membership
pm me your email if you would like to see them
jsut three pics, two of the antenna, and one of the display module all using velcro
good luck
good luck
Originally posted by Rambunctious
here's the pics
good luck
here's the pics
good luck
membership = pics = good information
