Changing spark plugs and wires? >
Old 06-10-2003 | 06:37 PM
SteveO's Avatar
Default Changing spark plugs and wires?
How often do you guys change the spark plugs, wires and do a general tune up? Check the timing or anything else. A friend of mine just purchased a boat (97) with 250hrs on it, 454 EFI, 385hp. Had a mechanical survey done and the guy said everything was fine but he should have a tune up done.....wires, plugs, rotor cap? check the timing. The guy wants $250 to do it. Is this a every 100hrs thing or a as needed thing???
SteveO is offline
Old 06-10-2003 | 08:00 PM
mopower's Avatar
Toxic FORMULA
Usually do mine every other year. I average 50hr a season.
mopower is offline
Old 06-10-2003 | 08:01 PM
Ric232
My opinion only:
To maintain optimal performance, you should change the plugs, cap and rotor once per year, but you can certainly go longer. Even a slightly corroded cap and rotor can have a significant impact on top end performance. Plug wires rarely have to be changed because the engine compartment in a boat does not get very hot. He can change the cap, rotor and plugs himself for a grand total of about $40.
Old 06-11-2003 | 08:44 AM
mcollinstn's Avatar
I've lost three sets of Mercruiser plug wires in 400 hours. Twin BBC, well-ventilated engine compartment.
I've gotten to where anytime I detect a stumble, I get in with the motors and watch and listen for arcing. It's been the plug wires more times than not.
mcollinstn is offline
Old 06-11-2003 | 11:45 AM
bobby daniels
Ric above is right if you start with good wires like mC below him said they break alot on some boats !!
Plugs and cap and rotor 1 time a year and wires if you use say Taylor Pro series 409's once every maybe 4 years ,there are alot of good hi-po wires out now Taylor I like but their hard to make
MSD is second order from summit ,ect
Old 06-11-2003 | 04:49 PM
bobby daniels
Troutly you can I think order them from summit to fit if not I'll make you a custom set Labor free and send them just advise what color ,I've made 3 sets this week already ,be sure to get the pro wire
GK
4
06-26-2008 07:45 AM
rangerrick63
06-10-2007 08:15 PM
gripit
7
04-01-2007 09:57 PM
formula31
11-03-2002 08:43 AM
puder
2
08-31-2002 11:25 PM
