went from a 22 Velocity(fast&nimble) to a 26 Velocity (slow&lazy
I know I will need seat time but it felt like somone threw an anchor off the back of my boat. had my 22 for 9 years and dialed it in perfectly. 76.5 on gps with a 22" chopper. This thing makes me think IM driving a truck, got 66.5 on gps. I would like to know what the best set up is for the rough as well as top end. If these two meet. Engine height,drive,prop. It has a 502 with an estimated 400-450 hp for know. After its dialed in I will add power.
Is this a 260 (24 ft) or 280 (26 ft)?
What prop and rpm are you running? 66 mph is slow. I would expect you to be in the low 70s with a 502 in a 260 and 69-70 wit a 280.
I agree with Padraig. I had a 280 w/stock 454/300 and the boat ran 63.5 GPS with a 24 hydromotive at 4400 rpm. With 502/415 the boat should run about 70 running a 26 hydromotive @ 4800 rpm.
This is the way street's number shake out of my slip calculator. 13.5% is probably generous. This calculator has proven quite accurate for me.
MPH
Input:
rpm 4800
pitch 26
constant 1056
gear ratio 1.5
slip % 13.5
Output:
mph 68.15
MPH
Input:
rpm 4400
pitch 24
constant 1056
gear ratio 1.5
slip % 13.5
Output:
mph 57.67
I personally think 66.5mph is quite respectable, especially when you get into larger boats. The fun of a larger boat is in the rough, not the flat. This is probably a pardigm shift from the 22' boat. In fact, I don't even like to go out when it is flat. Running a 30' scarab w/ twin 468cid turning 4900rpm with 25p mirages, 68.1 gph so far... still optimizing. My slip is high for some reason.
BT
MPH
Input:
rpm 4800
pitch 26
constant 1056
gear ratio 1.5
slip % 13.5
Output:
mph 68.15
MPH
Input:
rpm 4400
pitch 24
constant 1056
gear ratio 1.5
slip % 13.5
Output:
mph 57.67
BT
I take that last statement back... haven't plugged my numbers in for a while. This is what the calculator says about my slip now. It was previously 16.5% before some improvments.
SLIP
Input:
rpm 4900
pitch 25
constant 1056
gear ratio 1.5
mph 68.1
Output:
Slip 11.94%
I'm not going to get any more speed until I find some more rpm (ie hp) to support a higher pitch.
BT
SLIP
Input:
rpm 4900
pitch 25
constant 1056
gear ratio 1.5
mph 68.1
Output:
Slip 11.94%
BT
I am certainly no prop expert Street, but I have heard that effieciency (slip) goes up with blade surface area (diameter). Pitch should not affect it. Again, I am no prop expert and if my answer is wrong, let me hear it. My calculator does not take into account blade area, only accounts for it as slip.
BT
BT
