502 Water pump impellar?
The impeller is rubber and the blades come off. Sometimes you can see in the back of the pump through the water hose nipples.
The pieces go to the next restriction in the cooling system-usually the oil cooler and they really can cause a restriction. Look at the pieces you get out and you can tell if you have enoughm if not, FIND THEM!!!!!!!!
terrygar
1
08-02-2002 09:36 PM
