Prop Torque, Pitch change >
Old 06-21-2003 | 09:12 AM
Elite Marine's Avatar
Default Prop Torque, Pitch change
I purchased a prop from a fellow OSO member, thought I was getting a RH roation, ended up a LH rotation. I'm going to try it and see if it works and if it actually counters the engine torque.
I have read about the zincs with the fin on them, would they help reduce the torque effect?
I'm running 28P prop, but want a 29P. The Bravo1 isn't offered in a 29P. Would I be better off buying a 30P and having it detuned to a 29P or buying a 28P and having the pitch increased to 29P?
Elite Marine is offline
Old 06-21-2003 | 08:42 PM
Blackhawkdn
Bravo props are actually 1" less than stated, a 30" is actually 29"
Old 06-21-2003 | 10:22 PM
HOUSTONPROP's Avatar
Question changing pitch on prop
when changing the pitch of a prop, it is recomended to change no more than two inches up or down, any more than this will cause blade distortion and it will not perform correct,To me, it does not matter which way you go ,either way requires heat and is alot of work.But when going up you can add cupping which allows you to get a little more than you would if going down in pitch because diamenter is very important to keep.
Darin
HOUSTONPROP is offline
Old 06-21-2003 | 10:56 PM
So you're saying I'm better off with a 28P than a 30P to make a 29P?
Old 06-21-2003 | 11:04 PM
Default prop pitch /Pantera
Yep.you are right on the money Pantera /Talk to you later Darin
Yamaha 225
Prop Talk
10
10-08-2008 05:43 PM
Powerquest_Baby!!
Prop Talk
6
12-06-2006 06:48 PM
Led Sled
5
01-08-2005 12:48 AM
powerguy
16
08-16-2004 08:24 PM
CelticPride
3
12-11-2002 06:17 PM
