Re-installing fuel tank, what foam should I use? >
Old 06-22-2003 | 11:51 AM
Question Re-installing fuel tank, what foam should I use?
Will "great stuff" in a can work or should I use the 2 part stuff?
Pure Energy is offline
Old 06-22-2003 | 08:39 PM
Audiofn's Avatar
Charter Member #232
Use the 2 part stuff that is LOW expansion, or just pour a little in at a time. For true coast guard aproval you need to use the correct stuff. Good luck.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-22-2003 | 09:10 PM
wwwTOPDJcom's Avatar
ya great stuff Expands TOO much
wwwTOPDJcom is offline
Old 06-22-2003 | 09:27 PM
Andy Buzz's Avatar
Any fiberglass supply house will offer one gallon cans of two part foam available in two pound four pound etc density. Check www.glueproducts.com I am guessing around $50. Like audiofn mentioned, put in a bit at a time. The stuff rises like a cake, sands easily, and can even be fiberglassed over. Great Stuff will melt if you try to fiberglass over it.
Andy Buzz is offline
Old 06-22-2003 | 11:18 PM
Bulldog's Avatar
Are you going to coat the tank with something before you foam it in? I am getting ready to put mine in and am going to use Gluvit from West Marine. It is a waterproofing epoxy that remains flexible. After I foam them in I am going to seal the top of the foam. AndyBuzz is right, use the 2 part stuff.
Bulldog aka Ronnie
Bulldog is offline
Monza SS 24
Detailing, Painting, & Fiberglass
6
02-27-2007 09:22 AM
NJgr8ful
05-13-2006 10:52 PM
Pure Energy
06-27-2003 07:15 AM
rws
5
02-01-2002 08:50 AM
Air Eddie
2
01-31-2002 08:04 AM
