Water Temp on Blower Intake >
Old 06-23-2003 | 09:26 AM
VelocityMark's Avatar
Question Water Temp on Blower Intake
OK another question about a Littlefield intake for a 1071. Where is everyone picking up water temp. It has two places for water on the front of the intake that takes a #10 AN fitting and two places on the rear for #8 fittings to dump water from but no place to pick up water temp HELP.
VelocityMark is offline
Old 06-23-2003 | 10:32 PM
paradigm shift's Avatar
I have mine tapped in to the water passage in the front of the heads right before it goes to the intake manifold. We use to run them that way all the time when I ran a flat bottom v-drive. I just drilled and tapped a hole for the sender. You may have a spot on your manifold you could do the same thing. I am not real familiar with your intake. I run no thermostat so water temp nevers sees 130 anyway.
paradigm shift is offline
Old 06-24-2003 | 02:19 PM
bobby daniels
I'd see you buddy, budah and get a whipple intake and intercooler and use it with the 1071 he's even got he right plate for a 10-71 I understand and cheap (trade for grayson ??? ))
BillFormula
Wanted
1
03-11-2008 05:56 AM
Smitty
10
02-02-2008 11:02 AM
bajamag
08-20-2002 12:21 AM
Mrgoodwrench
3
03-25-2002 11:43 PM
Miguel
2
03-25-2002 11:04 PM
