Oil Pressure
JUST FINISHED REBUILDING 2 454'S
TOOK THE BOAT FOR THE FIRST RIDE, WHEN I STARTED THE MOTORS I HAD 60, LBS OF OIL PRESSURE RAN THE BOAT FOR 1/2 HR CAME TO AN IDLE AT 600 RPM'S I HAD JUST UNDER 20 LBS OF OIL PRESSURE IM RUNNING 30 WT OIL (VALVOLINE) WILL A DIFFERENT WT OIL HELP THE OIL PRESSURE ?
I'm curious what was the problem with the motors before they had to be rebuilt? Was it lack of oil pressure?
Heat will allways create a lack of oil pressure, I know i just grenaded a motor last year in 15 minutes, the boat mechanic must of had some shop worker with limited knowledge assemble my motor. It had the same characteristics, fine at idle then very low oil pressure, let it cool and up it came back.
The bad news is when i pulled the motor it completely destroyed my crank and the berings were like little chips of granuals everywhere.
Is yours comming back. What is your oil temp? I think in your case it is probably oil wt. I boat in extremely hot weather so I use a 50 wt out here.
Be cautious, I included a picture of the damage i incurred with the same symptons.
Krumbsnatcher,
I don't feel so bad now, my HP 500 (rebuilt by experts???) last 1hour. Managed to save crank. Start all
Watch those pressure over again & I shoud be running this weekend 2month delay. Started with great oil pressure & slowly dropped down & then the knocking started
Later John
Later John
Ok so we know we can break these motors, now how do we find the answer for OPA?
I now have mine rebuilt and back in the boat, still not running the big dog, hopefully soon summer is starting to cook the lakes.
Try and run a mech. gague ,alot of problems are sender or gage related !! I run a #4 braided or cloth braided line to the fron from the front main as this is the point that looses oil first and I can really tellthe pressures then ,its critical to say the least ...
Change to a 20w50 or 15w50 and it will fix the problem if its oil related (READ THE POST ON HERE OIL TEMP IN BBC) its good on oil problems
What bearing clearances are you running ?? what type oil pump I like the mellings HV pumps they work great or the manley pumps
high volume ones are even better
but the guys are right temp does it in if ,if the rest of the motors fine ??? let me know I'll try and help
I run straight 40 weight Castrol racing oil. Mercury recommends at least a 40 weight oil.
just 2 cents worth
solid weight thickens as it cools and thins alot as it heats ,muilt vescosity works much better to protect you investments
20 pounds at idle after a hard run is not bad, especially with 30wt. Isn't the old story that you should have 10 pounds per 1000 rpm? Any idea what the oil temp is?
Steve Gresham
'03 Donzi 33ZX
Steve Gresham
'03 Donzi 33ZX
