Airating a Black Hawk? >
Old 06-26-2003 | 11:36 AM
Airpacker's Avatar
Default Airating a Black Hawk?
I am wondering if anyone has designed and or used an airation tube on a black hawk drive to ease planing. It seems I have so much dam bite now that planing has become a task in itself. I thought getting the props to hook up was going to be tough, I was way wrong. Getting them to loosen their grip so I can build some rpm is the problem now. I was thinking of trying a 1 1/2" tube and feeding the leading prop. Any ideas or suggestions/experiences?
Airpacker is offline
Old 06-26-2003 | 12:24 PM
Official OSO boat whore
I've heard of it being done, but I havn't ever seen it. Somebody made the parts for the job. I'm thinking that it was Teague.
How's that thing working on your boat?
Cord is offline
Old 06-27-2003 | 07:37 AM
jollyroger's Avatar
AirPacker...
Did you put the BlackHawks on with the proper X-dim, or did you bolt them on in the stock Bravo location?
What pitch BlackHawk props are you using? What type of power does your motor have?
Do you have thru hull exhaust?
The Blackhawk drives are designed to be used with thru-prop exhaust. The exhaust from your engine is supposed to aerate the props. If you look at the way the exhaust exits the drive, it is designed to aerate the props. If you are using thru hulls, and it is set too deep (X-dim) that might be a small part of your problem.
If you want ping me, [email protected]
Woodsy
jollyroger is offline
Old 07-07-2003 | 02:11 PM
Airpacker's Avatar
Well,it seems that my airation system worked well. The props loosened up and now the boat planes easily. If your interested,I can tell you how I did it.
TomFTM
Wanted
2
03-31-2010 03:28 PM
drbab400
Eliminator
1
04-24-2007 10:15 AM
Wardey
08-01-2004 11:58 AM
Fast Forward
21
01-27-2003 11:54 AM
