Go Back  Offshoreonly.com > Owners Forum > Sunsation
Left hand on 288?? >
Left hand on 288??
Left hand on 288??
Old 07-01-2003 | 08:12 PM
Kanookstr's Avatar
32' SUNSATION
Question Left hand on 288??
How about it??? Has anyone tried a Left handed prop on there 288???
Wondering what it would do for High speed chine walking, and top speed???
Right now my 288 with a 28"P bravo 1 chine walks over 72 mph.
I can usually drive thru it to get to 80 MPH, But It's not fun
Also going to try a Hydromotive 4 blade this weekend to see if it helps with speed and walking. The boys at Hydromotive seem to think so????
Kanookstr is offline
Old 07-02-2003 | 10:25 AM
Reckless32's Avatar
Rough Seas Lie Ahead
It's hard to nip the chine on a single application especially with an 8'1" beam and large pitch props without increasing weight and shying to the starboard side on a right hand application and vice on a left hand. I would think a left hander would increase a single's chine due to less weight (drivers weight sits starboard) on the port side to counter torque?...
Reckless32 is offline
Old 07-07-2003 | 01:02 PM
daveb
Kanookstr, Have you tried the hydromotive? I'm having same problems,wondering if it helped. What pitch did they recommend for your 288. I think reckless288 post is right, but any little thing would help. Daveb
Old 07-07-2003 | 01:42 PM
Kanookstr's Avatar
32' SUNSATION
Yes I did try a Hydro this weekend daveb, It was slower, and it created way to much transom lift. I lost about 4 MPH. Going to try a 29" 3 blade maybe this weekend.
So far I can spin my Bravo 1 4 blade 28" to around 5200-5300.
But keep in mind Reckless and myself are super charged, not stock.
My 288 came with a rev 4, 23" stock. but they went back to a 24" bravo 1 .
Old 07-08-2003 | 08:57 AM
daveb
I also have a supercharged 288. I'm working with mercury racing dailing in props. Thanks for the info on the hydro. , let me know how the 3 blade turn out.
Old 07-08-2003 | 11:31 AM
Kanookstr's Avatar
32' SUNSATION
Yes, Yes I will daveb, You keep us informed as well with merc racing props
Old 07-12-2003 | 11:21 PM
Question
Kanookstr couple questions, I am looking at buying a 288. Does the chine walk happen all the time at that speed? You said you can drive though this, does the chine walk stop after a seretin speed? Power boat magazine mention this in dec 1999 with the HP500. How do like the your boat? thanks.
nitro/max is offline
Old 07-14-2003 | 01:54 PM
Reckless32's Avatar
Kanookstr, I'd love to be super-charged, but I'm just a plain ole run of the mill stock guy. You're probably thinking of Splinter....
Old 07-14-2003 | 08:10 PM
Kanookstr's Avatar
32' SUNSATION
Yes your right Reckless288, I ment splinter
Nitro/Max I love my 288, It's my favorite boat to date, but it's not an easy one to drive at speeds above 70...I did notice that on water with 1.5+ chop, the chine walking is a little more controlable. But on anything less than 1.5' chop, It's tough...
Old 07-15-2003 | 09:16 AM
Reckless32's Avatar
It's hard to get an offshore hull to run stable in glassy conditions due to the sharp deadrise which is meant more for cutting/slicing than running high plane. A Friend of mine had a 22' Donzi with a 350mag and a step. The boat would not run straight and level on smooth water no matter what you did trim/tab wise. It would flop to one side or the other. In some chop it ran flat and comfy....Just some additional insight....
