Bravo Spacer ?s >
Bravo Spacer ?s
Bravo Spacer ?s
Old 07-02-2003 | 08:43 AM
Default Bravo Spacer ?s
I have XR drives with half inch spacers in them. I just got a one inch spacer from Merlin540. I want to use the one inch on one drive and the two half inch spacers on the other drive.
What bolts and couplers do I need.
What does a coupler look like?
Will the two half inch spacer work as a one inch spacer, or will they leak?
Any other advice is appreciated.
thanks in advance
Shawn
shawn is offline
Old 07-02-2003 | 12:09 PM
You need:
6 studs that are a 1/2 inch longer than those you have now.
A coupler that is made for a 1" spacer--it connects the upper and lower gears together.
The aluminum sleeve that fits the spacer.
2 seal kits--might not need them, but its a good idea to put new ones in.
All of this stuff comes with an IMCO spacer kit. You will have to get the coupler and sleeve from them. The studs you can probably find, but might as well get them from Imco too.
Griff is offline
Old 07-02-2003 | 12:12 PM
Just saw that you have XR's. The list I gave is what is needed for a standard Bravo. The XR is probably the same, but I'm not for sure.
Griff is offline
dogindave
0
07-18-2008 10:50 PM
dogindave
0
07-09-2008 06:55 AM
Dude! Sweet!
Wanted
5
01-17-2008 07:07 PM
OPA
07-30-2004 11:26 PM
batboatracer
1
07-06-2002 01:01 PM
