Exhaust Water Hotter on Starbord Pipe >
Old 07-02-2003 | 06:13 PM
BAD-HABIT's Avatar
Default Exhaust Water Hotter on Starbord Pipe
SBC running thur hull 4" exhaust and Alpha drive. I was wondering why the water exiting the exhaust is MUCH warmer on the starbord exhaust than on the port side. The boat has always done this with the old motor and the new "Problem Child".....
BH
BAD-HABIT is offline
Old 07-02-2003 | 10:43 PM
Aces & Eights
Mine does the same exact thing. One side (port) is warm, the other (Starbord) is so hot you can barely touch it.
The engines are running about 165 dg.
Old 07-03-2003 | 02:32 AM
BAD-HABIT's Avatar
Forgot to add....my temps are about 150-160*
BH
Old 07-03-2003 | 07:28 AM
formula31's Avatar
Mine too, all of them, ever. I think its normal at idle. I assume they equalize at speed as the pressure and flow increases.
formula31 is offline
Old 07-03-2003 | 08:24 AM
blue thunder's Avatar
You need to make sure the plumbing runs are identical (side to side) going to the exhaust manifolds. If one side has longer runs, higher runs, more turns ect, it will get less flow. The sides need to be balanced. The other consideration is the state of the inside of the manifolds. Too much corrosion is one will cause the other the win the flow battle.
BT
blue thunder is offline
Old 07-03-2003 | 03:12 PM
BAD-HABIT's Avatar
BT
Lenghths are identical. Note quite sure about what you mean by balanced. Did it with the old stock manifolds and the new Stainless Marine ones....
BH
Old 07-04-2003 | 08:23 AM
Greg Mc
I have an '86 Scarab 21' with the 5.7/Alpha set up. Mine does exactly the same thing, hotter on the starboard side. I am also running in the 160-165 degree range. It steams occasually after slowing down from a beating.
Old 07-04-2003 | 10:47 AM
BAD-HABIT's Avatar
Seems like alot of people having the same symptoms but nobody has an explanation
BH
Old 07-07-2003 | 04:42 PM
Balanced means equal number of 90s, similar elevations of hoses and a level tee in the front of the engine. If you are sure the manifolds are ok and your plumbing is balanced, you could try restricting the port side water flow to direct more flow to the sb side. This could be done by pinshing off slightly the hose going to the port manifold with a wire tie, just to see if you get a change.
Another area to consider is the "balls" in the thermostat housing. I've never had these on my boats, but they are common and if sticking can cause similar problems. Maybe a search on thermostat housings would turn up something additional.
BT
nordic95
11
08-23-2010 03:35 AM
88Maxim
Do It Yourself, Boating on a Budget
35
07-20-2008 09:45 PM
Jayl13
Apache
7
05-26-2006 07:34 AM
Jeff Pierpont
2
03-18-2005 09:00 PM
imq707s
2
02-22-2002 11:41 AM
