Engine Miss after blown hose >
Old 07-03-2003 | 09:31 AM
Scott72
Default Engine Miss after blown hose
Okay, finally got the boat in and out and because of my stupidity, I sliced a hose. When I changed the remote filter, I moved a water hose out of the way. I didn't put it back and the power steering pump pulley sliced it. By the time I realized it salt water was coming out like a garden hose all over everything. Didn't overheat but sprayed a lot of salt water all over the motor. Came back in and cleaned down everything, replaced the hose. Now the motor is missing. Don't think I took any down the carb (850 Holley), didn't see any salt residue on the throttle plates. Pulled all plugs and cleaned wires etc. Pulled cap and rotor to be sure and ignition module and cleaned it up. Anything I am missing here? Have an extra ignition module I can try. Motor is 461 (475hp) running stock Thunderbolt IV iginition.
Old 07-03-2003 | 12:05 PM
formula31's Avatar
Its usually plug wires. Cant think of anything else.
formula31 is offline
jeff32
04-23-2008 09:49 PM
speeddemon651
Velocity
3
03-23-2008 09:21 AM
GCAT911
Fountain
0
09-23-2007 06:47 PM
Bikini Bottom
11
09-09-2005 02:01 PM
MnFastBoat
2
10-13-2004 09:33 PM
