mufflers
Look for a pair of mufflers, Clamp on, on tips already thru the tramsom. 4" dia. Want to be full time, no additional parts, just mufflers. Any ideas on a good pair, and a good price?
Chapest would be the insert type, available from CP performance, Eddie Marine, etc. They also muffle well, but can cost some HP on bigger engines.
I have a set of Gil clamp-on externals (see in pic). Not quite as much muffling, think they were around $800 per pair when I got them several years ago.
-Greg
-Greg
Originally posted by Holeshot
Look into Bassett mufflers, they will slip into your 4" hose they are about 8" long and cause almost no power loss, I had slip in type from Rex Marine, lost 200 RPM
Jim
If you are intrested in the Slip in ones you can have them for $40 + shipping
Jim
BH
This question has popped up alot lately....I would do a search for silencers and mufflers...I personally use Drew Shotguns..Affordable,Adjustable,High-Quality and GREAT customer service..Do a search their has been lots of threads on them and others...
BH
BH
I run the Drew Shotguns and they work great for my application. My exhaust exit under water and the Shotguns nearly silence the exhaust at idle. At cruise and WOT they really don't do much, but they don't hurt performance. They can be adjusted so they reduce noise, but then there is a slight performance loss.
