trs help
Old 07-13-2003 | 04:49 PM
wetpleasure
Default trs help
Just got back from the lake. With either a drive problem or a trany problem. Was running down the lake at 3300 rpm when sudenly the the boat pulled to the one side and the rpm gauge went down then motor died. pulled the outdrives up and checked the prop. the prop looked good so lowered the outdrives and started the motors up when i shifted it in grear it died. Where should I start?
Old 07-13-2003 | 10:58 PM
Audiofn's Avatar
Charter Member #232
first make sure your drives turn freely. just grab the prop (WITH THE ENGINE OFF of course) and see if the prop turns easy.
Put your best foot forward!
Audiofn is offline
Old 07-14-2003 | 08:43 AM
Wally's Avatar
Were doomed!
Your gonna have to pull the drive off to figure this one out....since the TRS drives are a direct drive, if the trans is locked up you wouldnt be able to turn the drive....and make you think its a drive problem.....pull the drive off and then turn it. If it spins then i would start on the trans. By the way...did you check the trans fluid? does it smell burnt or is it black? may be a quick way to check before hand....
Same thing with the drive....pull the bottom fill/drain plug and check the oil out and see if you have any metal shavings in the oil..
-Wally
Wally is offline
Old 07-14-2003 | 08:30 PM
We really got NEI (not enough info.) here. I'm guessing that this is a twin power rig since you talk of "motors and out-drives" as plural. What trannys you got? B/W or MerCtransII? First thing I'd do is pop the top cap on the TRS and you'll probably see the problem.(destruction). Hope I'm wrong but BTDT. (been there,done that) You really don't have to pull the drive to check that out. If the engine runs in neutral but dies when you shift, I'd say that the drive is toast, and it's most likely the upper. You could be REAL lucky and have it just be a seized bearing. Good luck! --- Jer
jpclear is offline
redcorvetteman3
Drives and Lower Units
14
10-07-2008 06:58 PM
GoFastSonic
Classic Offshore
8
05-12-2008 09:48 AM
42johnny
14
04-18-2008 09:49 AM
jeff1000man
02-27-2007 09:45 AM
