Lost Drive Oil In Resevoir On Bravo >
Old 07-14-2003 | 09:15 AM
Default Lost Drive Oil In Resevoir On Bravo
RAN GOOD AND HARD LAST WEEKEND, STARTED IT UP THIS WEEKEND ALARM WENT OFF, PULLED IT OUT OF WATER TO CHECK PLUG DIDNT COME OUT. FINE CHECKED TOP SCREW OIL THERE, FILLED IN BACK UP . ACTUALLY A LITTLE HIGH AT END OF DAY EVERYTHING FINE.
WTF
WHERE DID THE OIL GO ? WAS IT AN AIR POCKET?
SLINGSHOT is offline
Old 07-14-2003 | 09:28 AM
R Addiction's Avatar
AT Cult Member #3
Recent service? May have had a bubble down low.
Now the level is high after running it..........pull the lower plug and check for water. Oil floats.
R Addiction is offline
Old 07-14-2003 | 09:50 AM
NO WATER
Old 07-14-2003 | 10:13 AM
MitchStellin's Avatar
Check out the prop shaft, just a thought.
MitchStellin is offline
Old 07-14-2003 | 12:56 PM
mr_velocity's Avatar
Got a friend that is also losing oil in his drive. While on the lift one day I noticed oil seaping out of the right side of the drive where it mates to the bell housing. Figured it was the O-ring for the resevoir. Pulled the drive and replaced the o-ring. Still losing oil, any ideas?
mr_velocity is offline
Old 07-14-2003 | 01:15 PM
The prop shaft can loose oil and it is never seen unless on the trailer of a while. If in the water it may never show.
Old 07-14-2003 | 02:08 PM
dhlaw's Avatar
Pinion shaft seal has crept out of the carrier and burned up on the u-joint knuckle. Time for new seal with the upgraded carrier. The oil is sitting in the bellows.
dhlaw is offline
c_deezy
Drives and Lower Units
4
10-05-2008 08:13 PM
powerquest280
10
06-08-2008 07:52 PM
jdub
05-29-2007 06:56 PM
pachangalpina
1
07-27-2004 01:23 PM
Krumbsnatcher
2
05-26-2004 01:12 PM
