When it says E, it means E >
Old 07-14-2003 | 08:57 PM
Default When it says E, it means E
Wow, out fooling around on Sunday evening, pulling the tube around out in front of the marina before calling it a day, the gas gauge gets right down near E, I figure "ahhhh, we'll be ok, were just out front of the marina......." gauge getting lower,the SECOND it lines right up with the last line, dead centre of the E.....quits....done.....no restarting.......stranded.......toast.....have to get towed in 1/2 mi by a cruiser........I normally dont let it go below 1/4..........now I know..........when it says E........doug
pullmytrigger is offline
Old 07-15-2003 | 12:15 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Wonder if it is a Fountain thing.
My 27 would only read 3/4 when full. I could run for 3 months before it would start moving. At 1/2 reading, start looking for a gas dock. Don't THINK about thinking about getting gas.
1/2 -1/4 is only good for a few miles.
At 1/4 tank, the gas dock had better be within a stones throw distance, cause time you pull in, it will go to Empty. And it is!
Took 2 times to figure that out. Duh!
Wondering if my 32' is the same?
US1 Fountain is offline
Old 07-15-2003 | 12:28 AM
candyman35's Avatar
Don't trust the gauges. I ran out still showing a 1/4 tank. I reset my mileage on the gps when I fill up. It's way more accurate.
Dan
candyman35 is offline
Old 07-15-2003 | 06:39 AM
Jana's Avatar
Me too! Lucky thing, I was right in front of the marina when it happened and one of the boats came out and towed me in. Guess I should've watched that video before I took her out those first few times.
Jana is offline
Old 07-15-2003 | 07:03 AM
BAJA WILL's Avatar
Registered User
Yep, as soon as the needle starts to move around start looking for a Marina, if it moves past 1/2, you better be on your way to the marina
WILL
BAJA WILL is offline
Old 07-15-2003 | 09:08 AM
GotTheFever's Avatar
Ran out of gas and had to be pulled in by a pontoon boat. Gage said 1/4 tank, 2 minutes later, empty. Now I don't let it get below 1/2 tank. Problem is, when on plane, and the boat is bouncing around, it's hard to tell exactly where it is at. I normally judge it based on when the boat is still in the water.
GotTheFever is offline
Old 07-15-2003 | 11:49 AM
fountain27ho496's Avatar
Default Its a fountain thing
And people ask why I always top off..
Havn't run out, but my wife and I ran across cumberland
from jamestown to burn side, said 3/4, I topped it off
took 41 gallons. Holds 61, I was almost a bobber.John
fountain27ho496 is offline
Old 07-15-2003 | 05:27 PM
later's Avatar
My 42 will run on the low fuel lights for 20miles or better the port side has the fuel pickup shorter than the starboard side so you will always have one motor to limp home on
later
later is offline
Old 07-15-2003 | 07:34 PM
Mate 229's Avatar
The crappy little 61 gal tank is the only thing I hate about my boat. I also ran out 2nd time out. gauge just came off full and said time to head back. As I drove back to the ramp I actually watched it drop as I drove, when the little warning light comes on you're toast. I ran out at the mouth of the marina, luckily the wind was blowing into it and I floated in slowly to the dock, talk about luck!!!
Mate 229 is offline
Old 07-16-2003 | 09:55 PM
Ginger or Mary Ann?
Dan
Yeah, but Dan.............don't you have to run it out of gas once in order to know how far you can go?
