Drive oil leaking out of water intakes on side of drive >
Old 07-15-2003 | 07:50 PM
Default Drive oil leaking out of water intakes on side of drive
Did a seal let go between the uper and lower? I dont mess with outdrives.
Velocity Tom is offline
Old 07-15-2003 | 08:38 PM
Yep, most likely a bad seal between the upper and lower. Its a piece of cake to put in new seals. 6 nuts on the top and a bolt under the lower zinc and its apart. Just drain the lube first.
I never touched a drive till about a month ago. I installed a larger spacer between the upper and lower. It took me about 2 hrs start to finish and 20 mins of that was letting the lube drain out.
Griff is offline
Old 07-15-2003 | 08:43 PM
Yes thats what I thought to . I just had both drives done 10 hrs. ago.
Old 07-15-2003 | 08:46 PM
mpally's Avatar
When you say you just had the drives done 10 hrs. ago, do you mean they were gone through. If so, I would be placing a phone call to my mechanic and have it gone through again and done right. Either they didn't replace the seal or they did it incorrectly.
mpally is offline
Old 07-16-2003 | 10:13 AM
Ran-Dom 32's Avatar
just had my lower done 1 week ago - same thing, oil coming out of water intake after sitting for awhile, it's the little orange seal for the oil passage between upper & lower (mine was missing) sound like the same problem EZ fix.
Ran-Dom 32 is offline
JimmyBaja
Drives and Lower Units
3
11-20-2007 07:39 PM
kemiller
11
08-22-2006 07:01 PM
Chuck
5
07-19-2005 10:03 PM
gotime34
2
06-14-2005 02:41 PM
BAJA WILL
3
07-21-2004 10:57 AM
