Tie Bar Question
Old 07-21-2003 | 10:03 PM
VelocityMike's Avatar
Default Tie Bar Question
I need to buy a tie bar for my new project boat. I wanted to know if anyone knew where the best and the most cheap place to buy one would be?
VelocityMike is offline
Old 07-21-2003 | 10:16 PM
mcollinstn's Avatar
Maxx has one reasonably priced. See the thread on "hydraulic steering for under $500".
mcollinstn is offline
Old 07-21-2003 | 10:18 PM
Ted G's Avatar
Yup, they make some really nice stuff.
Or you could just get a length of 1" tube at West Marine and a couple of big ol' bolts and we can hook you up
Hell those Alphas are aluminum we can tap right in
www.cbpba.com
Ted G is offline
Old 07-22-2003 | 05:51 AM
Don't go cheap, I had a friend that lost his life because the tie bar broke and darted him up the bank and the boat flipped over. The fuel fumes is what killed him
Face It is offline
Old 07-22-2003 | 06:20 AM
Raypanic's Avatar
IMCO's are reasonable, Max machine works and Latham are pricey. New that is. I like the saddle mount these are the ones that mount on the trim mount pin, very sturdy. Look on www.cpperformance. com. If you buy the one for the rear caps you need to make sure the bolts clevises and caps all are the same size. Imco uses a different cap than latham. Also Imco uses a 5 bolt rear cap you have to drill and tap two additional holes. Latham does not.
Ray
Raypanic is offline
Old 07-22-2003 | 07:03 AM
cuda's Avatar
The best price I found was WPM. Seems like it was $316 or so. I bought it through Mastry Marine in St Pete, Fl. A freind of mine works there if you decide to get it there, tell him Cuda sent you. His email is [email protected]
cuda is offline
Old 07-22-2003 | 07:18 AM
Cignificant's Avatar
I've got a used one. Used two seasons. Currently set at 35 1/4" centers, but will adjust in/out about another inch each way. I believe I got it from Imco. I don't need it because the steering I bought came with one. $100 plus S&H and it's yours.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
SKRAMER
04-26-2006 08:31 PM
ratman
4
12-30-2005 10:23 PM
SeaWeasel
2
01-14-2004 02:31 PM
Scarab3DMC
04-27-2002 08:30 AM
