Rhodes lifters?
Any info on these lifters would be appreciated.
What is the theory behind the bleed down at low RPM?
What are the pros and cons of this lifter?
Are they noisey?
Paul
Are they noisey?
Paul
Official OSO boat whore
I had them in a past car. The idea is that they bleed down at idle for less lift. Pretty good theory. I think that it would only be needed on a real radical cam. Of course, everybody is running rollers today and they don't offer a hydraulic roller like that. Never knew why though...Anyways, they wern't real noisy. Just a slight tick.
My dad had a pair laying around from years ago. So we put them in a 454 we built.
454 .125 over
gm rect heads
merc 420 cam
rhodes lifters
12:1 comp
480hp/540tq
We don't have much time on the engine but seem to run really good!!
454 .125 over
gm rect heads
merc 420 cam
rhodes lifters
12:1 comp
480hp/540tq
Hmmmm. It sounds as though these lifters are obsolete.
Wonder why an engine builder would use these on an engine upgrade 3yrs ago? Question is to leave them in and run them or replace. I am afraid of lifter failure leading to something more catastrophic. Any opinions?
The way I understand, it is actually just the opposite. Bleed down at low RPM does not allow full realization of cam profile. When oil pressure is increased, lifter pumps up all the way to get full affect of cam profile.
After further research I am comfortable with these lifters.
Case closed.
Paul
Case closed.
Paul
