Pop in rebuilt 454
I have twin 454's in an early 36' Sonic (1984). They were run-out so I had them rebuilt a few weeks ago. While they run great now, I still have the same "pop" (backfire) in one of them that I had prior to rebuild. It occurs above say 3500 rpm; a single pop that may occur now and then again in 5 minutes sometime sooner sometimes later but if it's running over 3500 rpm, it's going to pop. I've swapped carbs, coils, thundberbolt IV packs. I've had 3 sets of ignition wire, plugs and distributor caps on it. Heads were replaced (old ones cracked) with new valves, seats, guides, springs. Running solid lifts & cam. Still have the pop in that engine. Appears to be through the carb to me. Will try swapping the Distributor itself this weekend. Out of ideas, any help would be greatly appreciated at this point.
Al
Al
Thanks for the response BT. Running Holley 750 dual pumpers, just had them rebuilt as well. What about potential bad fuel pump? Think that could be possible? I always want to believe it's either pumping or it's not. Any thoughts? Thanks again for the help.
Al
Al
Al
Al
Is it a metalic sounding pop? As if a metal popcorn kernel is in the engine. I had a similar sound in my 454. Ended up being a valve that was sticking and the piston was hitting the valve. It was happening anywhere from about 3800 on up. But mostly under hard acceleration. If so I suggest checking the whole valve train. I ended up losing the engine before getting it apart to fix. DOOHHHH. Anyway just my $.02. Hope its not that. Good luck.
Originally posted by Jersey Tom
Fuel pumps can be bad and still pump. The volume they pump determines whether or not the motor gets enough fuel. The fact that it comes and goes after a few minutes and is always above 3500 rpm makes me believe that you are running out of fuel and leaning out the motor.
Al
Al
Alcor, if the carbs are double pumpers they sell a dual bowl with a 1/8" pipe fitting that accepts a fuel pressure gauge, I found my problem thanks to the one I had my problem ended up being the pickup tube in the fuel tank had a crack in it and when the tank went low it sucked air then gas got swished around it took afew gulps of gas and sucked some more the gauge was going up and down, luckily I was on my way in. Y could also just hook an inline fuel pressure gauge also. Mine was a perm. setup
Al
