ATL Safety Fuel Cell Bladder Tank >
Old 07-26-2003 | 07:42 PM
Tom's Avatar
Tom
Default ATL Safety Fuel Cell Bladder Tank
Qty (1) Custom ATL Safety Fuel Cell Bladder Tank. Approx. 37 U.S. gal.
capacity. Bladder constructed of ATL 824-A. Includes SF103
safety foam and (1) 6x10 plate with 2" FPT fill, (1) #8 vent & (1) #8
fuel pickup.
Suitable for use with gasoline or diesel fuel. Price = $ 1383.00
Anybody have any experience with ATL? How will it handle all the banging around in offshore racing?
Tom is offline
Old 07-26-2003 | 08:17 PM
Steve 1's Avatar
Used them for years no problem except they seem to breathe gas fumes
Steve 1 is offline
Old 07-26-2003 | 08:59 PM
Tom's Avatar
Tom
Gas fumes are a bad thing in a boat, can you elaborate on the gas fume issue?
Tom is offline
Old 07-26-2003 | 09:23 PM
Steve 1's Avatar
Was just the boats always smelled like gas. its hard to beat a well designed well fastened in... metal fuel tank..
The Bladders have to be secured in a manner that does not allow movement.. strapping them down will not work as they flex around the restraint...
you actually need to build them into a form-fitting box type affair with a top on it..
I did the math one day By the time I added all the tie-down material and the fittings there was not much weight to be saved..so I designed new race tanks that were an epoxy coated round aluminum tank system in 8# foam and bolts on the cats and never had a problem..
Steve 1 is offline
Old 07-26-2003 | 09:32 PM
Monty's Avatar
ATL and FuelSafe are the industry standand in many forms of motorsports. Bladders must be enclosed by a suitable external, rigid container - generally aluminum or plastic, although steel is used in some cases. It depends on the requirements of the sanctioning body and the application. Properly applied, a FuelSafe or ATL badder/container system will exceed almost any OEM fuel tank arrangement.
Monty is offline
Old 07-26-2003 | 09:34 PM
Mike J
Tom, Check www.fuelsafe.com
in Bend Or.
541-388-0203
Tried and True.
Mike J.
Old 07-26-2003 | 10:37 PM
SHARKEY-IMAGES's Avatar
OSO Content Provider
Commercial Members
I used a 22 gal ATL in the 13 ft vee bottom that ran in offshore conditions all the time. Although this was not the flexible bladder type, it was the plastic fuel cell though. When I installed it I made it just snug to some angle aluminum and then ran two straps over the top. As Steve said about the fuel...After fueling it up, the tank expanded big time! I could have probably ran without the straps because it became so tight inside the aluminum.
I was very impressed with the fuel pick up design as well.
All in all, a great tank!
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 07-26-2003 | 10:48 PM
Ryan Beckley's Avatar
Racer
Racer
MANY offshore teams have used ATL cells for years. I have never heard anything bad about them.
Ryan Beckley is offline
Old 07-26-2003 | 10:55 PM
They seem to work great but be aware the foam in the bladder has a life of about 10years and it is a real pain to replace.
mmwalters is offline
Old 07-26-2003 | 11:28 PM
Commercial Members
Default Re: ATL Safety Fuel Cell Bladder Tank
fuel pickup.
$1383.00
So my 22 gallon tank that I am asking $299 for is a bit cheap huh?
www.TimSharkey.com/
