Cleaning Sportmasters
No, I had polished imco lowers. Not worth the work, I used Mothers, rubbing compound all sorts of stuff, none was easy. Now I just use a stiff wire brush and the "mat" finish is easy to keep up.
Ray
Ray
Speed2Lead,
Although the drives may look great on the trailer all nice and shiny, it really isn't what you need when they are in the water.
You want that satin finish. (One reason why Mercury makes them that way).
This will allow the drives to be aerated and not stick to the water as it passes around them.
Same theory on hull bottoms. 800 or 1000 grit sand paper on the running surface is usually enough to let the hull stay free.
They say a waxed bottom is much slower than one that has been sanded.
From experience with my circle racing with the Bullet, it worked for me....
Originally posted by sharkeymarine
Speed2Lead,
Speed2Lead,
MY THOUGHTS EXACTLY... WHO CARES IF THEY LOOK GOOD... IT IS ALL ABOUT THE SPEED!!!!!!!!!
I THINK IT IS A REAL HOOT WHEN I SEE PEOPLE WAXING THE BOTTOM OF THEIR BOATS....
REGARDS
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
