What limits the size of the prop? >
Old 07-28-2003 | 09:01 PM
Elite Marine's Avatar
Default What limits the size of the prop?
I'm running upwards of 640+ HP, actually 540 HP at 4000 RPM to 648 HP at 5300 RPM, yet I am only able to turn a 28P Bravo1 prop 4650 RPM.
It actually seems like as I push the throttle to the max, my HP drops off! Engine has less than 10 hours on it. I've taken it easy for break in, but want to run a little now!
Last year before the rebuild, I was able to spin a 29 at over 5000 RPM.
What limits the size of the prop I can turn, shouldn't it be the HP and torque? I should have enough of both to spin a 28P faster shouldn't I?
Just curious. . . and a little disappointed
Elite Marine is offline
Old 07-28-2003 | 09:04 PM
What is your HP and TQ curves every 250 rpm or so?
I bet 4650 is right near your TQ peak!
cobra marty is offline
Old 07-28-2003 | 09:21 PM
4000 - 542 HP, 711 Ft-Lbs
4250 - 580 HP, 716 Ft-Lbs
4500 - 604 HP, 706 Ft-Lbs
4750 - 623 HP, 693 Ft-Lbs
5000 - 628 HP, 661 Ft-Lbs
Peak Torque is around 4650, but the HP is still going up.
With a 4500# boat, Deep V whats the recommended prop. Darin at Houston recommends a 26 Bravo 1 repitched to a 27, cupped and labbed. I agree at this point, but just like to get several opinions/ideas.
Old 07-28-2003 | 09:36 PM
What speed are you running at WOT with the 28"?
I would try a stock 26" and get the numbers and then talk to Darin.
Before I labbed or cupped a prop I would test the 1 and 2" shorter lowers. Maybe trying different lower units (shorter) might help more.
Old 07-29-2003 | 05:36 PM
Shorter? I'm running a 17-1/4 X dimension already!
Old 07-29-2003 | 06:03 PM
Von Bongo's Avatar
I am turning a 28 labbed Bravo 1 4850 in 90 degree heat and high humidity with a 575sci on my pantera 28.
Something is wrong.
Von Bongo is offline
Old 07-29-2003 | 06:56 PM
hugetime1's Avatar
I think labing that prob would get you to 5000, but maybe a labbed 27 would be even better, you would probobly turn 5200-5300
hugetime1 is offline
Old 07-29-2003 | 08:24 PM
What could be wrong? Engine is strong, boat seems smooth and good. This is a stock prop no modifications.
Should still be getting the RPMs up. I'll try a 26P and see what happens.
High Tide - I ran the dyno. Did 15 - 20 pulls all the same.
Old 07-29-2003 | 08:32 PM
Dennis Moore
What is the drive gear ratio?
Dennis Moore
Old 07-29-2003 | 09:34 PM
Call Matt or Julie at Throttle-Up Props. These guys can get the most out of any prop, and they are the best people you will ever deal with.
Throttle-Up 727 531-2256
HighPriority is offline
