Pro's & Con's of strap vs. cable >
Old 07-29-2003 | 03:46 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Question Pro's & Con's of strap vs. cable
I am putting a winch on the front of a Myco trailer for a 47' Fountain. Any opinions or experiences of straps or coated steel cables? My trailer has a cable and has been fine, but I don't use it very much.
WARPARTY36 is offline
Old 07-29-2003 | 03:53 PM
CigDaze's Avatar
I prefer straps. They are very resilient and can take a lot of abuse. Often times they as as strong, if not stronger than the equivelant steel cables. They are easier to winch and wrap. Only drawback is that they can be cut and fray.
Coated steel is not very good in dealing with the elements. Even stainless cable will eventually rust inside the coating and the coating is affected by UV and will dry and crack. Steel will also work harden and break if bent repeatedly.
CigDaze is offline
Old 07-29-2003 | 05:11 PM
WARPARTY36's Avatar
I think this is a bit much for my driveway.
Old 07-29-2003 | 05:29 PM
Havasu Cig's Avatar
Go with a strap. My three previous trailers had straps and they are much easier to use (no tangles). Our current MYCO was suppose to have a strap but was delivered with a cable and I am going to change it.
Havasu Cig is offline
Old 07-29-2003 | 05:45 PM
CigDaze's Avatar
Ya, just a little.
CigDaze is offline
Old 07-29-2003 | 08:07 PM
ActiveThunderTodd's Avatar
I need to replace the winch on my Myco as well. Were are you getting your winch from? What do you think is the best one? Thanks
Todd
ActiveThunderTodd is offline
Old 07-29-2003 | 10:07 PM
Official OSO boat whore
Unless you are getting an electric winch, you'd want a two speed one. They have a low speed for really cranking on the cable, and a high for just winding things up. Try calling Tom's Trailers in Butler.
Cord is offline
Old 07-29-2003 | 10:41 PM
Quiet Storm's Avatar
If you go with the strap you should change it at least every other year. I've had a few break on me. They weren't cut or worn just broke unexpectantly. My new Myco came with a cable and at least I will be able to tell when its ready to be replaced.
Quiet Storm is offline
fountain4play
Drives and Lower Units
89
12-04-2015 05:03 PM
FeverMike
09-13-2007 10:00 AM
Budman
01-09-2004 02:51 PM
Cat & Mice
01-28-2002 08:20 PM
