Engine Vents disaster >
Old 08-01-2003 | 01:15 PM
JS232's Avatar
Default Engine Vents disaster
I got a 232 Boss running on lake Champlain. %$?#$ damn rough on some days. 2-3-4 feet shops. Last week, was running in 2-3 feet shops. Later, I discovered that the white calking that olds the left engine vent in place craked all the way. That calking broked all along the engine vent. Been able to replace the vent in place (quater of an inche distortion). So, I told my self that I needed some calking job on that side....
Wrong! Got back in some 1-2 feet shop. That damn calking made some small stress cracks on the gel-coat when it first craked. Guess what happened? I now got a 1 inch ship of gel-coat that stripped off.
Does that issue ever happened to 232-252-272 owners? Do you think it should be covered by the hull warranty? I bought the boat new last summer.
I am so disapointed. Always tought that Bajas where solid rock in the rough... I will now be carefull!!!
JS232 is offline
Old 08-01-2003 | 01:25 PM
Eternal Warrior
I never had that specific issue with my 232. I did have some gelcoat that chipped off (from what, I don't know) the first year I had it. It was covered under warranty with no questions asked. So I would assume yours would be as well.
Old 08-01-2003 | 06:10 PM
obnoxus's Avatar
Charter Member #1171
not on my 272
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-04-2003 | 12:58 AM
skygod's Avatar
No probs on my old 232.
Baja History
2000 29 Outlaw 2x454 mags (sold)
2000 25 Outlaw 502 (moved up to 29 OL)
1998 232 Islander 7.4 (got the 25 OL)
Tow Rig
04 Excursion EB PSD 4x4 6" lift 35's
MY PICS: http://community.webshots.com/user/skygod73
skygod is offline
Old 08-04-2003 | 07:14 AM
CigDaze's Avatar
Got pics?
No problems on my 25...
CigDaze is offline
Old 08-04-2003 | 01:14 PM
Dock Holiday's Avatar
Charter Member #34
Sorry,
Never had that problem on the 272, nor have I heard of it?
Good luck, hope you can get it fixed OK.
Dock Holiday is offline
Old 08-05-2003 | 02:11 AM
I've had the gelcoat crack around the vents on a 97 232, a 98 232, and a little bit of cracking in the caulking of a 99 h2x....all on the passenger side vent....
missouri is offline
Old 08-05-2003 | 09:36 AM
JS232's Avatar
Thnaks guys.
Missouri : My problem is also on the passenger side. Looks like there is finaly an issue with that problem. You think it will be covered by the 5 years hull warranty?
Are you a Baja dealer?
JS232 is offline
Old 08-05-2003 | 01:06 PM
I buy and sell a few boats a year but I'm not a dealer.....not sure about the warranty because all mine have been used...
missouri is offline
Old 08-05-2003 | 02:00 PM
Chris288's Avatar
same issue on my 96 232,, talked to baja and they said that those vents should have been put on using a flexible caulk, mine were affixed w/ someting along the lines of marine-tex. fixed it several times and kept happening. I finally used some 3M 5200 and it stayed. Then I got the stress cracks as you explain. I'm not happy, but it does not appear they are hurting anything.
Chris288 is offline
