Stains at the water line
Just got back from 7 days of boating on the Upper Chesapeake. Had a great time. However, now that the boat is back on the trailer what is the best way to remove the stains on the bottom of the boat and at the water line?
Simple greem is not cutting it!
I found that a mag wheel cleaner made for polished wheels works great! You just spray it on and hose it off. Also Marykate on/off sold in West marine but it is more expensive and you need gloves to use it.
Slimy Grimy is good, not as toxic as marykate onoff, but on/off works better. I mix slimy grimy in a 2 gal weed sprayer, makes it easy to apply. The on/off will eat away the rubber washers in any sprayer. First thing I do after salt water is put the boat into a freshwater lake and clean the hell out of it..... same with the trailer... I love my disc brakes, so easy to clean, no rust....
Charter Member #37 /Moderator/Platinum Member
Who sells Sno Bol. Some one else has recommended that and I can not find it anywhere
David
David
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
