502/425HP and 502/500HP difference >
Old 08-03-2003 | 10:22 AM
Cool 502/425HP and 502/500HP difference
What are the differences between the 502/425 and the 502/500HP(Carb)?
Are 502 crate engines still available?
Thanks!
RickR is offline
Old 08-03-2003 | 01:29 PM
Dennis Moore
Camshaft specs, valvesprings, intake manifold/carb and exhaust manifolds. Same shortblock, cosmetic differences. Yes they are!
Dennis Moore
Old 08-03-2003 | 02:51 PM
rjcardinal's Avatar
The ZZ502 has aluminum heads also.
Ron
rjcardinal is offline
Old 08-04-2003 | 08:39 AM
halffast_2003
wheres a good place to order one of these crate motors?
Old 08-05-2003 | 08:52 PM
try here
http://www.macmaster.on.ca/bbcrate.htm
chromecat is offline
Old 08-06-2003 | 04:02 AM
convincor's Avatar
www.offshoreperformance.com
give them a call.
I bought one from them in the spring for $4300.
There a hi-output marine version. I did a merlin intake with a 800 holley, gil exhaust.
Engine has run flawless.
convincor is offline
Old 08-06-2003 | 05:23 AM
Dave M's Avatar
Veteran: Navy
Originally posted by chromecat
try here
Some of these motors specifically say "not intended for marine use". What needs to be done to them to make them "marine" engines? Also, I notice that the HP500's from Merc are rated to run on 87 octane and the motors in the link above all say they need 92. I would like to have a 502/500 that can run on 87. Is that possible?
Dave M.
Dave M is offline
Old 08-06-2003 | 09:27 AM
tssteph's Avatar
I have a GM (automotive) crate engine in my Baja, it is the 425 hp 454 HO. I have not had any problems so far, I run 34 degrees of total timing with no pinging at all. I have ran some 89 octane when I had to and did not notice anything at all. Most of the time I run 91 if I can. corrosion is the issue from what I understand, also the water pump is defferent, my crate motor cam with the water pump and now it is leaking. Other information indicates that the automove water pumps can not handle the pressure of the sea pump.
Brian
tssteph is offline
bobt427
12-06-2006 11:34 AM
jvschlegel
8
08-10-2006 02:36 AM
jvschlegel
2
07-30-2006 08:12 PM
LA3
06-24-2005 10:45 PM
thedonz
01-04-2004 11:55 PM
