Spark plug detonation >
Old 08-03-2003 | 09:38 PM
p4-33's Avatar
Default Spark plug detonation
HP500 Carb motors, otherwise stock, and this has happened three times in the last two years. Porcelean blows out of the plug base, and I'm trying to understand if the damage to the electrode is a result of cylinder detonation or impact with side of the boat.
Changed the plug and seems solid again.
Anyone seen this?
Thanks,
Brian
p4-33 is offline
Old 08-03-2003 | 10:40 PM
I remeber hearing about this happening more often with a certain brand of spark plug. I don't remmeber which brand though. What brand are they???
Griff is offline
Old 08-03-2003 | 10:50 PM
ragtop409's Avatar
Cant answer any questions but I can tell ya a buddy of mine had an Autolite do the same thing in his strocker motor small block. We never figured out why? Rag's
ragtop409 is offline
Old 08-04-2003 | 07:02 AM
looks like you are way lean
THRILLSEEKER is offline
Old 08-04-2003 | 07:11 AM
p4-33's Avatar
The plug pictured is an AC Delco. I'm currently using Champions.
Doesn't seen to matter what brand. Random cylinders, too.
Earlier this spring I had a piston detonate in the #6 hole, but the plugs have only failed in #1, #2 and #4.
While the motor was apart, I saw no other evidence of detonation in these cyls.
Timing is 34 @3000.
Only happens on one motor, too. No problems with the other one.
This is kicking my ass, and I lost a race this weekend because of it.
Should I be looking at jetting? Flaky fuel pump? Ignition upgrade? what are the "hottest" plugs out there?
Thanks again,
Brian
p4-33 is offline
Old 08-04-2003 | 07:15 AM
formula31's Avatar
Your not running an MSD box are you?
formula31 is offline
Old 08-04-2003 | 07:32 AM
p4-33's Avatar
No, but considering it. Why?
Right now, the carb, dist, coil are all stock HP500 stuff from Merc.
p4-33 is offline
Old 08-04-2003 | 07:34 AM
p4-33's Avatar
Oh, the fuel pumps were switched to Holly Blue's by the previous owner.
p4-33 is offline
Old 08-04-2003 | 07:36 AM
formula31's Avatar
Sometimes the electronic boxes will intermitantly advance the timing enough to cause problems. Ive never heard of a Merc box doing it but you might want to change it to be safe. Never had a plug do that.
Old 08-04-2003 | 07:41 AM
Turbojack's Avatar
Detonation is what is tearing the plugs up. The good part is the plug is taking the hit. Detonation can/willl destroy an engine quickly. Need to find the problem. Hotter plug is not the answer. When you had motor apart could you get a guess on the compression? I would check the jetting.
Turbojack is offline
