What power tool do I need???
I am building a new Magnum and before it goes into the paint shop I want to cut all of the holes out for the hardware. Things like pop up cleats, vents, nav light, and things like that. I want to be able to make nice clean cuts and I know there is a power tool out there that will work the best, I just don't know what it is? Please Help.
Thanks, I've got one of those, I was just woundering if there was something that was kind of like a router. The thing I don't like about the air saw is I will go through blades every five minutes when cutting fiberglass. I guess that is just part of it.Thanks for the help.
I use Black&Decker (DeWalt) version of the "Rotozip" and have cut about 1/4 fiberglass on 1/2 plywood-(total 3/4") with good results using the carbide bit that they recommend for drywall. The tile cutter bit works very well also - just slower. --- Jer
Thanks guy's I'll try them both and am sure I will wind up using both before it is all over. The roto-zip will probably be better for the hard to reach areas. As soon as all of the hardware arrives, then I'll start cutting.
