headers (stellings) clearance questions >
Old 08-06-2003 | 05:21 PM
puder's Avatar
speel chekk this fokker!
Default headers (stellings) clearance questions
ok so everythign fit great on the tailpipe side of the equation BUT the front of the port header hits the damn power steering/alternator bracket!!!!
how exactly does that get remidied? who make a bracket that will relocate them and clear the headrs but still work with the main pulley belt locations???
shes getting damn close to running!!!
Pardon me, while I whip this out!
puder is offline
Old 08-06-2003 | 05:46 PM
DanB's Avatar
Charter Member #71
Lets see a pic...you might be able to get away with just a longer or shorter belt.
Dan
DanB is offline
Old 08-06-2003 | 05:49 PM
puder's Avatar
unfortunatly the bracket itself is in the way and its solid.
puder is offline
Old 08-06-2003 | 05:51 PM
puder's Avatar
look at teh header on the othe rside and you can see what the problem will be.
puder is offline
Old 08-06-2003 | 09:07 PM
sgrady's Avatar
Eickert had some, I wold try that, my power steering is on the left. Bu mine are also tall decks.
sgrady is offline
Old 08-06-2003 | 09:16 PM
bob
Charter Member #40
Default PS Bracket
Puder, can you mount the pump on the star side? Merc offers a mount for that side. It positions the pump a little lower than your bracket. I have ran mine there with Stellings.
bob is offline
Old 08-06-2003 | 09:43 PM
puder's Avatar
i unfortunatly put all my wiring crap on the other side and that headers just barely clear that as you can see. I am goignto call eikert tommorow. Any other companies you recommend?
puder is offline
Old 11-12-2008 | 09:27 AM
I have the exact same problem if you figure something out call me please Im ready to run just need to get this damn exhaust on
636-221-2023
schwoeppe_curtis is offline
Old 11-12-2008 | 09:49 AM
puder's Avatar
as i recall i took a stock bracket an cut half of it off. I was able to mount the pump much closer the center of the motor and just used a super short belt from and auto parts store.
puder is offline
Old 11-12-2008 | 09:51 AM
puder's Avatar
fyi it required that the steering pump and the alternator be mounted on seperate brackets.
puder is offline
schwoeppe_curtis
Swap Shop
19
01-07-2009 03:54 PM
CMMS
Swap Shop
7
10-09-2008 03:03 PM
awesomecat26
0
07-04-2007 09:16 AM
QUIKDECISION
3
04-17-2007 03:13 PM
