Exhaust Question >
Exhaust Question
Exhaust Question
Old 08-10-2003 | 06:42 PM
97BossHammer's Avatar
Default Exhaust Question
I pulled the quick/quiet tips off my hammer and while doing so I noticed a muffler type peice of metal inside the exhaust hose. Should this stay, or should I yank it out.....I tried pulling it but it's real snug in there. If this requires just buying a pair of new exhaust hoses thats fine too because the other hose has some inner peices tearing off.
97BossHammer is offline
Old 08-10-2003 | 08:04 PM
homan
If you have the 4" dia. hose from the riser to the exh. tip, that hose has an internally wound wire sandwiched between the plys of rubber you shouldn't see it at all. if it's at the very end of the hose then cut it flush and put on your new tips if it's in the middle of the hose where the exhaust and water pass thru replace the hose. that wire is to help keep the hgose from collapsing
Old 08-11-2003 | 07:19 AM
it's a pretty big metal peice....but it's on the port side only.....if it were to keep the hoses from collapsing shouldn't I have 2?
hpy540
8
11-22-2005 07:14 PM
THE GOOD STUFF
03-03-2004 09:17 PM
formula1
05-25-2002 07:59 PM
thisistank
Baja
17
03-24-2002 10:50 AM
