Rebuilding an HP500 >
Rebuilding an HP500
Rebuilding an HP500
Old 08-14-2003 | 08:04 AM
dowhat
Default Rebuilding an HP500
I have a 1999 stock HP500 with about 250 hours on it. I plan on rebuilding it this fall and would like more power.
1. How much more HP can I expect to get boring it 30 over making it a 509?
2. Since I will have the engine torn down are there any other suggestions for ideas to make more power and maintaining the reliability of an HP 500?
Old 08-14-2003 | 10:46 AM
Dennis Moore
You won't feel any performance increase by boring the engine oversize but you should increase the compression to 9.5:1 with open chamber JE pistons. The most important point, when rebuilding the engine, is to get the top of the piston to within .040 inches of the cylinder head with a gasket installed. A tight quench.
If you don't want to replace the large rectangle port heads with smaller oval port heads for increased torque production and a 20 horsepower gain you should at least install a dual plane intake manifold. The Edelbrock RPM air gap will give you more power (10 to 15 HP) than the Dart single plane at 5200 rpm. Keep the stock carburetor.
The stock 500 HP camshaft is great, I wouldn't replace it with anything larger. Keep the stock ignition system.
Sincerely
Dennis Moore
Old 08-14-2003 | 03:02 PM
Jack and Bobby, what horsepower will your changes generate?
shawn is offline
Old 08-15-2003 | 11:39 AM
Cool
Dennis and Budah
Are you suggesting the
JE Open Chamber Dome #123189 (Bore 4.469) 9.2@118cc
Thanks!
RickR is offline
Old 08-15-2003 | 01:10 PM
Dean Ferry's Avatar
Veteran: Air Force
Dowhat,
I too have a 1999 HP500 with about 175 hours and I am thinking about having Express Marine in Deland rebuld it this fall/winter, change out the springs and "pepping" it up a little bit. I live down the coast on Merritt Island. Are you doing the work yourself or having someone do it?
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 08-15-2003 | 02:00 PM
dowhat
I am living near St. Pete now, and I am not sure who I am going to have do it.
Thanks for everyones input.
Dowhat
Racerngr1
Drives and Lower Units
0
05-10-2008 11:47 PM
dogturd21
12
03-17-2008 11:19 AM
First Gun
Magnum Marine
14
03-21-2006 04:40 PM
paradigm shift
0
01-22-2006 10:55 PM
