Engine removal vs. winterizing
I actually found it was easier to pull the engines. It took just a little more time, was guaranteed to be done right, gave me a chance to give the engines a good once over, open them up, tighten everything, clean the bilge....the list is endless. The best part was being able to mess with them all winter. Oh, one more thing, I used the drives for end tables
"Pullin' mine"...The engines that is
Got a slight oil leak on the starboard one that I can't find from up top.
Worse yet , I've been living with a pair of new engines that just don't have the power they should have , and I refuse to give up prime time in the summer to pull them(as long as they're running)
Winterize with engines in boat. I bought a large rubbermaid bucket large enough and long enough to put my outdrive down in it. I pour about 6 gallons of antifreeze in there and about 6 gallons of water. I crank the boat and let it run until the antifreeze is coming out the exhaust. Its complete. (only works with no thermosat). If you have silent choice then it will still work. I have been doing this for about 6 years and never had a problem. Last winter the boat was in FL.
