25 Outlaw Cuddy Question >
Old 08-16-2003 | 07:51 PM
Steel Outlawed's Avatar
Default 25 Outlaw Cuddy Question
Has anyone ever taken the front panel in the cuudy out of a 25 Outlaw. This is the one at the bow. I looked at mine this morning, and there aren't any screws that are visible. Any ideas?
Steel Outlawed is offline
Old 08-17-2003 | 10:08 AM
liquid asset's Avatar
I think its just the lights and wedged in, but I could be wrong
liquid asset is offline
Old 08-17-2003 | 07:55 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Jeff:
Took mine off. There's 2 screws below the v-berth pad and then the lights. you'll need to remove the side pads running down the length of your cabin. There's screws right where the seams meet. I have some pictures of what it looks like with it off. I took mine off and added a mirrow, but think I'm going to put in a larger LCD up front and a center channel.
I can send them to you if you want. Email me.
Jim
Blue by You is offline
Old 08-27-2003 | 09:13 PM
I don't know if anyone will ever need this information, but I thought I would share it will this thread was open. The '99 is different from 2000 and above 25 Outlaw's. There are only two screws that hold this panel in and they are behind the lights, so you have to remove the lights, then there is one screw on each side you remove those and remove the side pieces and it comes right out. I installed two speakers in this panel to complete the surround sound for the dvd and tv. It worked out very good. I finally had to call Baja to get this one figured out. I will have to say they were extremely helpful and very easy to get information from. If you ever have a problem call Allan Lewis at Baja.
Old 08-28-2003 | 06:26 AM
bikinilover's Avatar
How is the paint coming?
bikinilover is offline
Old 08-28-2003 | 06:37 AM
I got the first rendering this week. It was a little more wild than I was expecting, so he's working on another one. Maybe we can get the design done in a couple weeks. I will not take it until winter probably around January or February. He said it should not take him but 2 weeks to do it.
Old 09-02-2003 | 07:09 AM
Good Luck! I hope it turns out OK.
MOERON
01-20-2008 09:55 AM
groundstrike
Baja
0
05-23-2007 02:09 PM
imartin
Baja
6
01-29-2007 11:07 AM
Outlawcowgirl
Baja
19
08-30-2003 10:41 AM
goob
Baja
11
06-20-2002 09:03 PM
