steering poor at low speeds >
Old 08-17-2003 | 02:47 PM
technicalx's Avatar
Default steering poor at low speeds
I just purchased a '98 Hammer with a 7.4L and Bravo I drive. When in the no wake zone, steering is poor. To keep fairly straight, I must turn the steering wheel back and forth constantly.
Once out and in open water, steering is fine.
Is this normal with a 21ft boat or is there somethng I can adjust? I've played with the trim while in the now wake, but doesn't help much.
It's extremely difficult trying to line up with the trailor!
thanx.
technicalx is offline
Old 08-17-2003 | 07:33 PM
Dennis Moore
The problem is not with the boat but with the driver! Just kidding, but you have the trim all the way in causing the bow to be pushed down. This makes the boat wander at low speeds. Trim the bow up a little (move the drive up) with the outdrive power trim. The trim tabs should be up also.
Dennis Moore
Old 08-17-2003 | 08:43 PM
Audiofn's Avatar
Charter Member #232
Do you have a fin on your zinc? I know they can cause some slow speed issues as well. All the Baja 240 sports that I have ever driven wander at slow speeds as well however.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-17-2003 | 09:41 PM
cuda's Avatar
It's the nature of the beast. All the single I/O's I've driven tend to "hunt" at low speed.
cuda is offline
Old 08-17-2003 | 11:49 PM
robyw1's Avatar
Raising the drive a little helps a little bit. My 22' Bravo Scarab has the same problem. You may find that backing up is a pain too, again in this case raising the drive helps... a little
Roby
robyw1 is offline
Old 08-18-2003 | 12:05 AM
paradigm shift's Avatar
Trim up a little and tabs down all the way will straighten it out. I know but try the tabs it works.
paradigm shift is offline
Old 08-18-2003 | 07:22 AM
Scott's Avatar
Charter Member #30
I also run tabs down to stop the search.
I have Steps & Bubbles!
Scott is offline
Old 08-18-2003 | 08:02 PM
technicalx's Avatar
Well, it may be the driver...but I going with the majority. I'll work on the drive and tabs and find the sweet spot.
Thanx for everyone's feedback.
wet_rat
Drives and Lower Units
18
04-02-2008 09:09 PM
BadDog
2
05-15-2007 01:44 AM
phatkat
09-28-2004 04:55 AM
