HP500 valve covers >
HP500 valve covers
HP500 valve covers
Old 08-22-2003 | 07:17 PM
PatriYacht's Avatar
Default HP500 valve covers
Can I use late model HP500 valve covers on my Merlin heads with .630 lift cam. I was about to buy a pair but the owner didn't thinkthey would fit.
PatriYacht is offline
Old 08-22-2003 | 10:10 PM
homan
I f the HP 500 valve covers say Mercruiser and are chrome the moron that did my boat doubled up on the gaskets to clear the rockers
Old 08-23-2003 | 05:14 AM
Crazyhorse's Avatar
My boat has the Merlin rectangular-port heads and Crane Gold rockers with the HP500 covers. They have had the oil deflectors ground off on the inside but still use the stock o-ring gasket. I believe my cam is slightly short of .600 lift though. Mock it up and you'll be able to see what it's going to require for gaskets.
Crazyhorse is offline
Old 08-23-2003 | 08:39 AM
mcollinstn's Avatar
You'll need to grind a little off the corners of some of the rockers (if you're using Crane Golds).
I've got a few sets of 1" spacers for valve covers lying around.
mcollinstn is offline
Old 08-24-2003 | 12:46 PM
Crazyhorse's Avatar
Yeah, mine has one rocker on each side that's had a corner dressed on a grinding wheel. But I've seen this on all the engines equipped with these covers as well as the older Cyclone/Weiand covers.
Old 08-25-2003 | 06:15 AM
PatriYacht's Avatar
Thanks everyone
98itrwhite
Wanted
1
04-07-2008 05:46 PM
tscarab
3
01-20-2006 07:53 AM
mtgbiker
1
11-01-2005 06:48 AM
nobudget
3
04-10-2002 01:27 PM
Cat & Mice
02-15-2002 08:13 PM
