bravo drive will not engage >
Old 08-24-2003 | 09:48 AM
hello all. have a 2000 342 baja with 502 mpi , bravo 1. out for a cruise, leaving the dock, my port drive will not engage. shift linkage is fine, the drive will shift into forward and reverse. prop is free and will rotate by hand. problem is the coupler is spinning around the drive shaft without the drive shaft moving, and as you can imagine creates a lot of whinning. question, is this a spun coupler?? if not what could be the problem, and also the cure?? any help would be appreciated.
KBUSH1 is offline
Old 08-24-2003 | 11:55 AM
Thumbs down
Looks like you'll be pulling an engine...pain in the ass just to replace a $200 part though..
good luck..
TROUBLE MAKER is offline
Old 08-24-2003 | 01:52 PM
Yup, I hate to say it but it is a spun coupler. and you do have to pull the engine to replace it. Check your motor mounts. They go almost always because of engine miss alignment. Good luck. To have it done is roughly a 700 to 1000 doller job.
Gary C is offline
Old 08-24-2003 | 03:59 PM
Mr Gadgets's Avatar
Charter Member #601
KBUSH1
It sounds like a dead couple to me. The motor will have to come out to remove the bellhousing to replace it. And Gary is right you need to check your motor alignment and make sure you use the proper grease for the coupler.
Good luck
Dick
Mr Gadgets is offline
Old 08-24-2003 | 06:36 PM
thanks for the replies. why does this happen??
KBUSH1 is offline
Old 08-24-2003 | 07:09 PM
Vinny P's Avatar
I hate the winter!!
There are a few reasons why this happens.
Age.
Engine alignment.
Abuse.
Not necessarily in that order.
Vinny P is offline
Old 08-26-2003 | 09:29 AM
pulled the engine last night and replaced the coupler. took me roughly 4 hours. not to bad. hope to be in the water on thursday. thanks for the help...
KBUSH1 is offline
Old 08-26-2003 | 08:44 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Don't forget.....engine alignment is a MUST, or you best have another coupler on order.
US1 Fountain is offline
switzer master
Drives and Lower Units
20
06-21-2007 08:20 AM
Mark D
16
05-02-2007 05:09 AM
kennythebus
2
06-28-2004 08:08 AM
Chris288
1
04-13-2004 11:19 AM
panteraracin
3
02-07-2002 10:36 PM
