Go Back  Offshoreonly.com > Owners Forum > Sonic
correct amount of trim >
Old 08-25-2003 | 08:37 AM
Default correct amount of trim
I have a 260 and can not seem to get the trim correct. I can't seem to get it to stop porpoising from 3200 - 3400 rpm. Less or more I can get it to ride fine. Any tips?
sonicator is offline
Old 08-25-2003 | 08:55 AM
Love Machine's Avatar
When the boat is out of the water I would take a yard stick or a 3 - 4 foot piece of wood and find the neutral points on the drives and trim tabs on the indicator panel. There was an article about this in Powerboat Mag a couple months ago. Basically, put the stick flat on the hull and ajust the drives/tabs until they are parallel to the stick. Then mark your indicators on the dash.
Once on plane and you have indicators in the nuetral spots then you can make small adjustments to reduce the porpoising.
Love Machine is offline
Old 08-25-2003 | 02:05 PM
birdog's Avatar
Yep....What LM said..........
Running the tabs at neutral {level} helps alot of boats..
birdog is offline
Old 08-25-2003 | 04:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The boat will do that a bit, especially full of fuel.
Which trim tabs to you have. 12" Bennetts? 16" Bennetts? 280S K-Planes? I would highly recommend the last two I just mentioned.
Running them at neutral, or just below (tip even with bottom of hull) should help you out. If you have the 12s, you will have to drop them down a bit farther.
Sydwayz is offline
Old 08-26-2003 | 05:53 PM
I have the 12's. Is it worth going to bigger tabs?
Old 08-26-2003 | 11:36 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
ABSOLUTELY! Best upgrade I have done to the boat. Do you have dual rams? The upgrade is VERY EASY if you do. Just remove the old tabs and plates, drill a few new holes for the new plate, (it has two rows of holes, and the lower row lines up with the existing holes, or at least it did on mine.)
Give Bennett a call, and talk to MJ Thomas.
http://www.bennetttrimtabs.com/help.htm
He could not be nicer; or easier to work with. Best customer service in the biz.
Sydwayz is offline
502ss
10
09-11-2008 07:09 AM
SANLEONKID
06-15-2007 08:43 AM
Ca$hed Out
Insurance and Finance
11
12-19-2006 08:03 AM
sonic28
0
08-21-2006 07:48 AM
Danny_Ocean
0
04-16-2004 11:43 PM
