4blade vs 5blade speedmaster props >
Old 08-26-2003 | 10:28 PM
johnnybegood's Avatar
Default 4blade vs 5blade speedmaster props
what can be expected switching from 4blade to 5blade speedmaster props same pitch and dia. cat with inward rotation. how will tail lift etc. be effected
johnnybegood is offline
Old 08-27-2003 | 04:09 AM
HOUSTONPROP's Avatar
Default SWITCHING 4 TO 5 BLADES
You will have less slip ,and they will acclerate much stronger,and run alot smoother,as far as tail lift I, would think having a extra blade working would creat more stern lift with these props.Darin
HOUSTONPROP is offline
Old 08-27-2003 | 12:09 PM
Darin,
I talked to you yesterday about work on my props and saw this post.I have the Kaama drives on my cat with 4 blade 17X28 props and I thought that I had too much slip.The 5 bladed prop caught my attention.Are these readily available in the used market.By the way I have a bunch of props I need to unload if you know of anybody
1 set each of 3 bladed long shaft 19 spline 29's and 26's and one set of short shaft 23's if you klnow of anybody.
Mark
fishead is offline
Old 08-27-2003 | 12:25 PM
Default props
Yes, I remember talking and have all the notes,I think they would be very hard to find go with the original plan and let me know the results on Monday,Have a good weekend and nice talking with you Mark.
Darin
Old 08-27-2003 | 06:50 PM
Mark, how are you making out with those small blocks from New Jersey?
Shawn
shawn is offline
Old 08-28-2003 | 01:16 PM
Shawn,
The engines are unbelievable.They run great and have tons of power.The problem I am having is finding the right prop.I am running a 28 four blade with a 17 diameter and it is still not enough but I cannot afford to keep on buying props to try.I am going to get some GPS readings this weekend end see what I get and see if the props can be tweeked up a couple of inches.If you run into some 4 blade large diameter and long shaft props for #3 drives let me know.I think I may need low 30's on pitch.
Mark
fishead is offline
Dueclaws
Prop Talk
9
06-08-2006 09:10 AM
tomcei
Prop Talk
2
03-31-2006 10:25 AM
boatman747
4
03-23-2006 05:26 AM
Nykamp
Prop Talk
0
02-23-2006 04:48 AM
Perfectmix
2
06-18-2003 09:47 PM
