HELP!!  7.4L/330HP with Issues! >
Old 08-27-2003 | 07:55 AM
jollyroger's Avatar
Unhappy HELP!! 7.4L/330HP with Issues!
HELP!! A friend of mine just sent this to me. Its a 7.4L 330 Fuel Injected motor.
When I run the boat at full speed (4200 RPM's) it could take anywhere between 15 and 45 minutes before the engine cuts out. I can watch the tach go from 4200 rpm's to 0 and then spike back up to 4200. It will keep doing this sporadically. If it is not doing that, while at full throttle I can watch the tach drop from 4200 rpm's to 3800 and remains there. If I keep running it, it will drop to 3200 RPM and stay there. During both of these occurrences the boat will no longer idle it will stall. If I let the boat sit for 15 minutes or so the problem goes away and I have to wait another 15 minutes or so to see it happen again. I can run the boat at 3200 RPM's and never see the problem. The marina has run a fuel pressure check and that was OK , replaced the coil and replaced the computer I think he called it the ECM. The error codes the computer originally gave him was a knock sensor and the ECM. Any Ideas???????
jollyroger is offline
Old 08-27-2003 | 08:25 AM
tssteph's Avatar
As a test diconnect the tach, I have heard of two boats with the identical problem you described and it ended up being the tack causing problems with the ignition system. It might be worth a try. The fact that it runs fine after it cools sounds like a ignition module problem.
tssteph is offline
Old 08-27-2003 | 07:26 PM
Vinny P's Avatar
I hate the winter!!
When the motor died on you, did you check for spark and fuel? You have to determine which is droppping out on you before you change parts.
Vinny P is offline
seef158
2
06-12-2007 05:44 PM
carter38
13
02-04-2006 03:56 PM
Fightclub
28
04-21-2004 03:23 PM
convincor
20
10-17-2003 03:59 AM
Wildfire
03-29-2003 09:43 AM
